- Fri Jan 22, 2021 6:17 pm
#12185
Hi All,
Recently got a Juki LU 563 and the full Lucky Needle courses. I have done a few pre-made cover installs but sewing is fairly new to me.
One thing I haven't seen addressed yet is replacing individual panels in seats, such as a damaged side bolster or seating surface.
When you unstitch the damaged panel what is the technique for installing the replacement panel. Obviously we can include seam allowance on the replacement panel, but what to do about the seam allowance on the original cover pieces? I am assuming you do not sew down the old stich lines which would likely be weak?
Do you trim off the old seam allowance at the stitch line and make the replacement panel larger? Adjust seam allowances to be as small as possible?
I see this as being even trickier if the replacement panel is to be single reinforced or French stitched to an adjacent panel. I would assume this requires replacing multiple panels if not a majority or all of the cover.
Thanks!
Thanks!
