By LeatherJohnny
#1964
I have always thought that upholstering headrests must be difficult because of the tight curves and the clips that hold the cover in place... :scream:
I have just seen a YouTube video in Russian that shows how the amateur trimmer makes and fits a cover for the headrest and it looks very good and seems very doable...
These Russians work very precisely!! It's a pity that I don't understand a single word!!! :slight_smile: :slight_smile: :slight_smile:
#1965
I just did some work on a Triumph TR6 and one of the headrests had a wear hole in it so I took it apart and replaced that side panel. It was a relitively easy job and remaking the whole thing would not have been too difficult. Jump right in.
LeatherJohnny liked this
By LeatherJohnny
#1968
Wow!! It looks as if it came like tbat from the factory!!! :grinning: :grinning: :grinning: Thank you, as I was afraid that it would be very difficult! (or at least for me :wink: )
Perhaps sewing a french seam in the headrest would be harder, without using a post-bed sewing machine? When I sew a french seam in intricate panels, I wish that the flatbed machine that I use could transform into a post-bed one :stuck_out_tongue_winking_eye:
#1972
@LeatherJohnny thanks, I got lucky and had a scrap that matched the color and texture pretty good. I don’t think a French seam would have been terribly difficult, why not try making a practice one from vinyl and see how it works for you.
By LeatherJohnny
#1974
Thanks again, and when I have some spare time I'll try to make one for my car and will let you know how it goes! :wink:
@LeatherJohnny ,
Listen to us Johnny. Go to the wreckers and get some headrests they are the very first thing I started with and are not as scary as they look :wink:
By LeatherJohnny
#2006
BigRig wrote: Mon Jul 16, 2018 4:42 am @LeatherJohnny ,
Thanks, and it's good to know!! When I see aftermarket upholstery jobs in cars it's not rare to see wrinkles in headrests and it made me think that they were difficult to do. I will keep you posted about my advances! :wink:
Hey cool video!
Some headrests are much harder than others. It depends on how difficult it its to get the cover on. Sometimes what I will do is put a thin trash bag over the head rest and install the cover. This helps to cover slid on much easier.
By LeatherJohnny
#2083
Thanks! Yes, I have used the plastic bag method in a couple of projects and it helps a lot!!! In my case, I used the very thin plastic that is used to protect furniture when painting the house :wink:
It was very interesting when I found out the vacuum bag technique, and it also helps when installing headrest covers. There are so many things to learn... :nerd:
By LeatherJohnny
#2563
In one of the videos he mentioned that it was masking tape, the one that painters use. I have used it to make patterns, and it works beautifully :wink:
Your proposed approach is generally sound and is s[…]
