Hello all.
I have been combating this issue with my Singer 241-13 for sometime now. Thread doesn't pass through the shuttle hole but outside. Tried solving but not able to. I have adjusted the holes on the throat plate and shuttle to help sew heavy materials and leather. I have just realized the thread doesn't pass through the shuttle hole.
#2564
@Miker,I'm not able to upload pics for now.
But the looking at the machine again I realize it is able to pic thread from bobbin but the main problem now is when I want to use a thick thread to sew. The upper thread keeps fraying and tearing. I tried but not able to resolve.
#2576
@Hope Komla ,
I was having major issues with my thread fraying and tearing as well. I tried almost everything I could and eventually found a mechanic that knew how to resolve the problem. If you have the option I would recommend getting the sewing machine serviced at a shop.
#2587
Make sure everything is very smooth. You could have a sharp edge or a burr somewhere that is causing the thread to fray.
Also @BigRig has a point. Your timing could be off. See if your manual has instructions on setting the timing or you can take it in to get serviced.
