By RonAlves
#9633
Hey everyone, In John's videos he talks about using chip board for patterns or door panels when not using ABS. It looks almost like poster board, but stiffer. I need some for the back of my new (Jnnkyard) seats for the back panel. Thank you for any info.
By RonAlves
#9754
Thank you John, I am not quite ready to spend over $60 for one sheet of ABS right now, all I need is to make two door panels and maybe a headliner for my 41 Truck.
@RonAlves ,
Go to the hardware store and look for 4x8 sheets of corrugated PVC board. It may be more affordable but the sewing through is questionable.
#9761
Another option is PVC that is not corrugated. It has been a couple of years since I bought it locally but a 4x8 sheet of 3mm ( 1/8” )was $22 and worked really well. It is a solid panel. Water proof and can be heated and formed. Holds glue and staples.
I buy mine from a company named Advanced Plastics. I know the have locations in my part of the country but not sure if they are nation wide or not.
By RonAlves
#9762
Thank you everyone for the help. I am thinking about just buying a sheet of 1/8 wood panel for about $10.00 Since I want to just add some door panels that never had any except the all steel panels that came with the truck in 1941. But I will also look for the plastic sheets here at my Home Depot only 1 mile from my house.
@RonAlves ,
There is a very thin plywood at homedepot you can use.
By RonAlves
#9767
Thank you Big Rig I went there yesterday and found a damaged sheet and got a great discount
