I would like to make a kite and just wondering if anybody ahs ever made one and if there is a supply place for the framework.
#10414
I have made a Flexifoil copy once, was a ton of work and I got to find out why good kites are so expensive, I also have quite a few Revolution kites that I’ve had to operate on every now and again. I put a ton of hours on them and eventually the spars wear through the leading edge.
These guys should have raw spars and their probably relatively close to you https://www.canadiankitecompany.com/
