By hapyrdr
#4070
Getting ready to order contact cement to glue down laminate for my new work table. first thought was to order landau and top contact cement but then wondered if that was what I wanted so looking at original contact cement. So the question is what really is the difference ? I've used a lot of contact cement over the years gluing on vinyl tops and such but that was in the 70'sand even sprayed through spray guns I figured I'd have some left over is why I started to get the landau top cement. Is it thinned to make spraying easier? :confused:
I have used landau top contact cement for laminate tops before. It work good. Im not positive but it think the only difference is Landau Top Contact cement is formulated for higher heat and more flexible. For laminate tops youll want to apply the contact cement with a roller not a spray gun. You want 100% coverage on both parts
