By Paul Williams
#4074
What thickness plywood sheet is being used, in south eastern Ohio it gets extremely in a closed car in the summer months so I was trying to stay clear of ABS material and 1/8 Haywood is hard to find locally. All I have found is 1/8 tempered hardboard.
By Paul Williams
#4096
I found some today at a specialty lumber supply close to me, they had (1) 4' x 8' sheet. That won't be enough to do the entire wagon but it is a start. I got one door panel cut out today.
I think menards has it but as a floor underlayment. Not sure if it’s 1/8” might be more 3/16”. Ive used it for other things than floor underlayment and had good results. I would think being under floors it would have to take moisture pretty well. Might give this a try?
