By blewitt
#13777
I am making a banquette for my lounge and am having trouble in buying the correct length of foam. Most of the sheets are too short. Any ideas please
Exactly what I do. You wont be able to see or feel the seam in the foam if you glue it together nice and lined up.
By Cpowen
#13856
I'm thinking of dou Ling the foam on my outside cushions. The manufacturer used 2" foam, rapped is with batting on top and bottom, sealed air tight with a kind of plastic bag and stuffed it in a 4" cover. It has now all depressed. Have you run onto anything like this before and do you see a problem with doubling the foam? Thanks
