By Jim
#14862
Good morning. I am planning to replace these springs for a 29 Chevy coupe with a solid piece of foam on a plywood base. What density foam do you recommend? Should I have layers of differing densities? The total height will be about 7 inches.
Thank you, Jim
Its really all up to you and how soft or firm you want it. A lot of people go with 70lb 3371 on the cushion and 2555 55lb. In general you want the cushion do be a higher density because it will have most of the weight on it.
By Jim
#14869
@John Thank you John. I appreciate your input. I hope all is going well for you down there.
Jim
Thanks! Everything is going well. We love it out here in the south. Hopefully the shop build will start moving forward soon.
MalcolmM liked this
