By Rug Dr.
#18010
I have a question.
Pontiac solstice and Saturn Sky. I'm working on the center console, it's just a trim pannel tha tcover the E brake and wires.
I pulled the vinyl off it to fix some craking. The vinyl was rubber backed, it's a first. Also another first is the staple with a 1/8" leg on them, 3/8" crown ith a 1/8" leg, CRAZY. I've google the staple with no luck.
Has anyone seen a vinyl with a rubber backing? No luck finding gthat either???
Thank you
By Ron Henningsen
#18011
Sure I use these staples all the time.
3 8 crown 1 8 leg.jpg (1.2 MiB) Viewed 7852 times
Hopefully the attachment which is a picture of the staple box label will give you all the info. Otherwise I"ll type it all in.
By Rug Dr.
#18013
Thanks Ron. The the cover or cosole is plastic and came with te 1/8" 71 series. I googled the size, 71 series 1/8" leg and nothing came up.
