By ratrod53
#5480
hello all
ok what I have is s 51 Chevy sedan delivery ,, I need to know how to curve the water board I got at the shop , I need to redo the back corner panels ... the left side is glued right to the corner panel now but it 106 in Nevada where I live and it is coming off.. the left side is a corner panel that has shrunk ... can any one explain how to bend the waterbord for the corners , I would like to make the panels one peace from the front doors to the back door... but I need to know how to bend the corner panels.....
Thank you :sunglasses:
By jdenison89
#5719
I think hes referring to "weather board" its the black water resistant panel cardboard. Ive used it before. You can actually shape it by spraying it with windex and then forming it into the area. After it dries it retains the shape. Afterwords you can also a apply a thin layer of fiberglass resin to help keep the shape and help weatherproof it a bit more. It also becomes more sandable at that point to make for a smoother surface when applying material.
