Just finished a floor with 2 circles for table mounts. They were pretty close to the edge and were manageable to get through the machine. If there is a case where the circle binding is in the middle of a large piece of floor and cant work it under the machine what do you do? Any tricks? Another way to stich it?
Just gotta roll, cram and fight it through. I always split my piece from table cutout to the edge (usually aft) so it can be installed/removed while the table is in place. Splitting it helps with fighting it through. @BigRig, i like sunbrella acrylic braid for binding vinyl flooring. It takes tight curves better than bias cut. Would love to get a carpet serger one day though.
