Any upholsters out here do steering wheels. If you do what is your way of creating a pattern with spokes ? I cant seem to get right.
By Dmitry_CAD
#22777
Hey there! Spoke patterns can be tricky, but here is a foolproof method most of us use to get a perfect, wrinkle-free fit:
The Cling Wrap & Tape Trick
• Wrap the spoke area in plastic kitchen wrap first. This stops the tape from bonding to the foam and stretching out when removed.
• Layer high-quality masking tape over the wrap. For extra precision, add a layer of duct tape on top to create a stiff shell that holds its shape.
• Use a fine marker to draw your seam lines and a few cross-marks (hash marks) for alignment.
• Carefully cut along the lines, peel the tape off, and stick it onto heavy paper.
• Make small relief slits on the curved edges so the template can lay completely flat. Trace it and add your 3-5mm seam allowance.
Two Golden Rules for Success
• Under-size it: Leather stretches. Reduce your final pattern width by 3-5% (about 2-4mm). You want to really pull the leather under tension to close the seam—this is what eliminates wrinkles around the spokes.
• Skive the edges: Always shave down the leather edges that tuck behind the spokes or under the plastic trim, otherwise the factory trim won't snap back into place.
P.S. By the way, my main passion and expertise is upholstered furniture! If you are into sofa and armchair manufacturing, make sure to check out my other threads. I regularly share production-ready furniture blueprints and technical drawings there. Also, I’m about to launch a brand-new thread dedicated entirely to hidden tips, manufacturing hacks, and trade secrets for making upholstered furniture. You won’t want to miss it!Feel free to drop by, download the blueprints, and let's build some amazing pieces together!
By Jake St Peter
#22780
Wow that’s is awesome. Thank you. I am also trying to do furniture. I will be checking it out for sure.
By Dmitry_CAD
#22781
Glad it helped 👍
Steering wheels can be surprisingly tricky, but once you get the pattern right, everything starts to fall into place.
Best of luck with your projects!
